January 1968 - December 1968
Bulletin No. 091 - May 3, 1968 [PARTIAL]
(21 articles)
  • Article 1369 - Air Conditioning Receiver-Dryer Restricted with Foreign Material - (1967 and 1968 Mustang, Fairlane and Falcon Units Equipped with A/C)
  • Article 1370 - Shudder at 15-20 MPH Under Moderate to Heavy Acceleration - (1967-68 F100-F250 with Automatic Transmission and 8 Cylinder Engine 131" Wheelbase)
  • Article 1371 - Supplement to Shop Manual Volume 3, Group 17, Adjustment of hood Latching Components for Maximum Engagement - (1967-1968 Light and Medium Truck F100-750)
  • Article 1372 - Alternator Regulator Damage Caused by Improper Wiring Harness Routing - (All 1968 Vehicles)
  • Article 1373 - Premature Flywheel Ring Gear and/or Starter Drive Pinion Wear - (All 1968 Manual Transmission Engines Except Super Duty)
  • Article 1374 - Reinforced Right Hand Engine Cover Side Panel - ("W" Series)
  • Article 1375 - Reinforced Left Side Engine Cover Side Panel - ("W" Series)
  • Article 1376 - Revised Clock Replacement Procedure - (All 1967 Models)
  • Article 1377 - Cortina Protective Wax Removal - Pre-delivery - (Cortina)
  • Article 1378 - Antenna Lead-in Cable Too Short - (Ford)
  • Article 1379 - Engine Ignition Noise in AM Radio - (All 1968 Car Lines with Philco AM Radio)
  • Article 1380 - Engine Date Code Locations - (Cortina)
  • Article 1381 - Erratic or No Transmission Shifts Due to Governor Valve Hang-up - (1968 Fords Equipped with FMX 3-Speed Automatic Transmission)
  • Article 1382 - Revised Procedure and Scheduled Time for Replacing the Headlight Cover Motor - (1968 Ford)
  • Article 1383 - Hard Cold Starting - 240 CID - (1968 Kansas City Built F100 Trucks with Standard Transmission and Carter Carburetor)
  • Article 1384 - Product Improvement - New Magnetic Donut for Warner Gear Transmissions - (1968 Light Trucks with Warner Transmissions)
  • Article 1385 - Service Rollers for Ownercard Imprinter - (All Models)
  • Article 1386 - Correction to 1968 Ford Truck Service Specifications Booklet and 1968 Bronco - 1969 Econoline Shop Manual - (1968 Bronco, 1969 Econoline)
  • Article 1387 - Ford Dorset Diesel Service Publication Summary - (1967 B-C-F and N 6000-7000 Series Trucks and Buses)
  • Article 1388 - New Intermediate Shaft Companion Yoke - 1968 & Past Model - (F, B, N 500-750 Series Trucks Equipped with Cleveland Steel Products Three Piece Driveshafts)
  • Article 1389 - Field Fix for Noisy Tappets After Prolonged Idle - (352, 390, 427, 428 CID Passenger Car and 330, 352, 360, 361, 390, 391 CID Truck Engines)
