January 1968 - December 1968
Bulletin No. 092 - May 17, 1968 [PARTIAL]
(15 articles)
  • Article 1390 - Excessive Engine noise Caused by Improper Choke Cable Installation - (All 1965-1967 F-100-350 Trucks)
  • Article 1391 - Temperature Switch Diagnosis - (All Car Lines Equipped with Temperature Switch Warning Lights)
  • Article 1392 - Engine Timing - (1969 Econoline with 240 CID Engine)
  • Article 1393 - Rear Wheel Seal and Wear Sleeves - (All Medium, Heavy and Extra Heavy Trucks Built After December 18, 1968)
  • Article 1394 - Vortox Air Inlet Cap - (W Series Trucks)
  • Article 1395 - Premature Brake Drum Wear and/or Noise During Brake Application - (All 1965 through 1968 F100/350)
  • Article 1396 - Heater Motor Without Blowers - (All "W" Series)
  • Article 1397 - Cortina Service Tools - (Imported Vehicles)
  • Article 1398 - Crimping Pliers Solderless Wire End - (All)
  • Article 1399 - Floor Member Reinforcement at Cab Upper Latch Mounts - (W Series - Non-Sleeper Cab Only)
  • Article 1400 - Correction to 1968 Ford and Mercury Shop Manual and 1968 Ford Car Service Specifications Booklet - (1968 Ford and Mercury)
  • Article 1401 - Oil Pressure Fitting Failures - (Detroit Diesel 8V-71 Engines)
  • Article 1402 - Piston for Body Lift Pump - ("W" Series)
  • Article 1403 - Correct Positioning of the "Tie Rod" Clamp Assembly - Front Axle Spindle Connecting Tube - (1966 thru 1968 Model Broncos)
  • Article 1404 - Revised Muffler to Inlet Pipe Attaching Bracket - (1968 W-1000-D and WT-1000-D Series Trucks)
cron
