January 1968 - December 1968
Bulletin No. 093 - May 31, 1968 [PARTIAL]
(17 articles)
  • Article 1405 - Rear Band Wear - (1968 Fords Equipped with FMX Automatic Transmissions)
  • Article 1406 - Engine Oil Fill - (All 1969 Econoline and Club Wagon)
  • Article 1407 - Inadequate Ground Wire Size - (1968 Bronco with Electric-Hydraulic Lift Kit No. C6TZ-19E537-D)
  • Article 1408 - Main Control 3.2 Timing Valve and Plug - (All 1967 & 1968 C-6 Automatic Transmissions)
  • Article 1409 - Black Paint on Engine Compartment Side of Hood - (1968 Falcon)
  • Article 1410 - Engine Harshness - 170 and 200 CID 6-Cylinder Engine with Automatic Transmission - (1966 thru 1968 Falcon, Fairlane and Mustang Vehicles So Equipped)
  • Article 1411 - Fuel Starvation - (All 1968 Passenger Cars and Trucks Equipped with Carburetor In-Line Fuel Filters)
  • Article 1412 - New Positive Stop Rocker Arm Stud - (1968 Thunderbird)
  • Article 1413 - Tape on Hood - (All 1967-68 F & T Model Trucks)
  • Article 1414 - Difficult Access to Rear Inner Dual Tire Air Valve - (1967-68 F & P 350/400 with Dual Rear Wheels)
  • Article 1415 - Engine Dieseling - (All 1968 Vehicles)
  • Article 1416 - Wheel Splash Enters Truck Cab at Cowl Side Vent - (1967-68 Light and Medium Conventional Cab Truck - Models F-100-F-750)
  • Article 1417 - Engine Compression Check - (All Cars and Trucks)
  • Article 1418 - Loss of Coolant - (All 1968 Vehicles)
  • Article 1419 - Body Lift Pump Repair Kit - ("W" Series)
  • Article 1420 - Floor Side Outer Member Sealing - (1966 and 1967 "W" Series Without Optional Left Hand Side Rear Step Assembly)
  • Article 1421 - Revised Lubrication Periods - (1968-69 F100/250 4x4 and Bronco - U-100)
