January 1968 - December 1968
Bulletin No. 096 - August 2, 1968 [PARTIAL]
(13 articles)
  • Article 1446 - New Front Spring Shackle Assembly - (All 1961-68 F, T, N, W, NT and WT Trucks with 4" Wide Front Springs)
  • Article 1447 - Driveshaft and Coupling Shaft Assemblies - (1968 Models F100/350, F100/250 4x4, E100/300, P350/400, P3500/4000 Trucks)
  • Article 1448 - 4 Speed Transmission (NPG)Shift Tower and Shift Lever Revision - (1968 F100, F350, F100-F250 4x4; P-350-500 Trucks)
  • Article 1449 - Correction to 1968 Cougar, Fairlane, Falcon, Montego, and Mustang Shop Manual - (1968 Cougar, Fairlane, Falcon, Montego and Mustang)
  • Article 1450 - Correction to T.S.B. Article No 1426 in Issue No. 94 of June 21, 1968 - Engine Knock on Acceleration - Transmission Flexplate to Crankshaft Retaining Bolt Torque - (Cortina Model "C" Units with Automatic Transmission)
  • Article 1451 - Automatic Moisture Ejection Valves - (N1000 and NT 850-950D)
  • Article 1452 - Front Spring Seat Installation - (1968 Bronco and 1969 Econoline)
  • Article 1453 - Rear Axle Noise Transmittal - (1967 Mustang Vehicles Equipped with the GT or Optional Handling Package [Excluding the Competition Handling Package] and Built Prior to January 1, 1967)
  • Article 1454 - Carburetor Altitude Calibration - (All 1968 and 1969 Passenger and Light Truck Units)
  • Article 1455 - Inspection of 1968-69 Vehicles for Carrier Damage
  • Article 1456 - Heater Hose Contacting Thermactor Pump Pulley - (1969 Econolines E100/300 with 240 CID Engines Built Prior to April 24, 1968)
  • Article 1457 - Water Leak at Front Door Weatherstrip - (1969 Econoline - All Models Built Prior to April 1, 1968)
  • Article 1458 - Plug-In Connection - Engine Wiring Assembly to Main Loom Assembly - (C & CT Trucks)
