January 1968 - December 1968
Bulletin No. 097 - August 30, 1968
(12 articles)
  • Article 1460 - Broken Door Window Regulator Handle - (1968 Truck Series F100-F750)
  • Article 1461 - Output Shaft Yoke Revision - New Process Gear 4-Speed - (1967-68 F100/350 and F100/250 4x4 Model Trucks)
  • Article 1462 - Rear Brake Adjustment - (All Cortinas)
  • Article 1463 - Automatic Transmission Fluid Specifications - (All Carlines, Light Trucks and Econolines)
  • Article 1464 - Crankshaft Vibration Damper to Engine Front Support Interference - (1967 "W" Series Trucks with Cummins NTC 335 Diesel Engines)
  • Article 1465 - Oil Cooler Line Restriction Resulting in Automatic Transmission Failure - (All Car and Truck Lines with Automatic Transmissions)
  • Article 1466 - New Fan Shroud - (N-Series Trucks with Cummins NH Diesel Engines)
  • Article 1467 - New Brake Shoe Retracting Spring - (All 1968 and Past model Heavy and Extra Heavy Trucks with 16½ x 6 and 16½ x 7 Eaton "S" Cam Brakes)
  • Article 1468 - Turn Signal Indicator Switch - (All Cortina Model "C" Units)
  • Article 1469 - Vibration During Braking - (1968 Fairlane, Falcon and Mustang Passenger Cars Equipped with Drum Brakes)
  • Article 1470 - Installation of Bonded Inside Rear View Mirror Button on Windshield Glass - (All 1967-68 Car Lines except 1967 Mustang)
  • Article 1471 - Alternator and Belt Splash Shields - (W Series Trucks with Detroit Diesel 8V-71 Engines Standard Cab Only)
WEBMASTER'S NOTE: This specific TSB is missing from my collection. The above index was compiled from the TSB Summary and may be incomplete.
