January 1968 - December 1968
Bulletin No. 103 - November 29, 1968 [PARTIAL]
(35 articles)
  • Article 1543 - Fuel lift Pump Diaphragm - (363 and 242 CID Dorset Diesel Engines)
  • Article 1544 - Correction to 1968 Truck Shop Manual, Volume 1, Assembly of Vickers Power Steering Pump - (All Vickers Power Steering Pumps)
  • Article 1545 - Steering Column Upper Bearing Retaining Screws - (1967-68 F-B-500-750 Series Trucks)
  • Article 1546 - 4 Speed Transmission and 4 Wheel Drive Transfer Lubrication - (1968-1968 F100/350, F100/250 4x4, P350/500, P3500/5000 and U100)
  • Article 1547 - Reverse Idler Gear Revision - New Process Gear 4-Speed Transmission - (1969 Model F100-F350, F-100-F250 4x4, P-350-P500 Trucks)
  • Article 1548 - Output Shaft Yoke Revision - Warner 4-Speed Transmission - (1965/69 F100/350 and P3500/4000 and 5000)
  • Article 1549 - New Exhaust Valve - Super Duty Engine - (1958-1969 401, 477, 534, CID Truck Engine)
  • Article 1550 - Rear Axle Wheel Bearing Adjuster Nut - (1969 and Prior 250 through 1000 Series Trucks)
  • Article 1551 - Touch-Up Repair Paint - Squire Model Station Wagons - (1968-1969 Ford and Fairlane)
  • Article 1552 - New 16 Inch Wheel - (1968-69 F-250/350 & 4x4 & P 350/400)
  • Article 1553 - Fairlanes Built with 302 or 351 CID Engines, A/C and No PVS Valve - (1969 Early Built Fairlanes)
  • Article 1554 - 4 Speed (T18) Transmission Shift Forks - (1967-1968 F100-F350, P-3500-P-5000 Trucks)
  • Article 1555 - Manual Transmission Clutch Adjustment - (1968-69 F-100/250/350)
  • Article 1556 - Rear Main Oil Seal Leakage - All 1969 Passenger Vehicles with 390/428 CID Engines)
  • Article 1557 - Inoperative or Intermittent Right Door Speaker - (1969 Mustang with AM/FM or AM/Stereo Tape Player)
  • Article 1558 - Improved Intake to Cylinder Head Gaskets and End Seals - (All Truck and Passenger Vehicles Equipped with 330, 360, 361, 390, 427 and 428 CID Engines)
  • Article 1559 - New Super Duty Exhaust Pipe - Muffler Inlet - (All Super Duty Equipped Vehicles)
  • Article 1560 - Cargo Door Opening and Closing Sequence - (1969 Econoline - All Models)
  • Article 1561 - Metal Squeak Noise in the Front Fender to Rocker Panel Area - (1969 Fords - All Models)
  • Article 1562 - Loose Accelerator Pedal Pad Bright Trim Cover - (1969 Mustang and Fairlane)
  • Article 1563 - New Fan Blade Assemblies - (1968 C-6000/7000 with 363 Dorset Diesel Engine, 1968 P-3500-5000 with 242 CID Dorset Diesel Engine)
  • Article 1564 - Conversion of Oil Bath to Dry Type Air Cleaner System - (1966½-7-8 "W" Series Trucks - All Engine Options)
  • Article 1565 - Possible Loss of Engine Lubrication Oil - (1968 F, B, C-6000/7000, F-T-C-8000 with Ford V-Series Diesel Engine - Caterpillar Mid-Range)
  • Article 1566 - Changes in Carburetor Dashpot Requirements - (Ford, Fairlane, Mustang and Truck)
  • Article 1567 - Brake Booster Air Intake Hose - (1968 B-600-750 with Frame Mounted Brake Booster)
  • Article 1568 - Cracks in Sealer and Poor Appearance of Sealer in Drip Rails - (1969 Mustang without Vinyl Tops)
  • Article 1569 - Engine Temperature Cold Light Deleted - (1969 Ford, Fairlane, Torino)
  • Article 1570 - Glove Box Light Stays On - 1969 Ford, Mustang, Thunderbird)
  • Article 1571 - Inoperative or Intermittent Fuel Gauge - (1969 Ford, Fairlane and Falcon)
  • Article 1572 - Servicing the Autolite Integral Alternator Voltage Regulator - (1969 Thunderbird)
  • Article 1573 - Instrument Cluster Plastic Bezels Crack - (1968 Fairlane - All Models)
  • Article 1574 - Shift Linkage Adjustment Procedure - 1969 Four Speed Floor and Console Mounted Shift Linkage - (All 1969 Passenger cars with Four-Speed Shift Linkage)
  • Article 1575 - Muffled Rear Speaker Output - (1969 Fords Equipped with Rear Speakers)
  • Article 1576 - Rear Axle Shaft Attachment - (1969 F250/350, E300, P350/400 and P3500/4000)
  • Article 1577 - Roof Panel Reinforcement Separated From Roof Panel - (1969 Econolines Built Prior to July 3, 1968)
WEBMASTER'S NOTE: This specific TSB is missing from my collection. The above index was compiled from the TSB Summary and may be incomplete.
