January 1968 - December 1968
Bulletin No. 087 - March 8, 1968 [COMPLETE]
(19 articles)
  • Article 1304 - Rear Axle Housing Alignment Checking Procedure - (1965, 66, 67, 68 Fords Equipped with Demountable Carrier, 1967, 68 Thunderbirds Equipped with Demountable Carrier)
  • Article 1305 - C-6 Automatic Transmission Reverse-High Clutch and Intermediate Band Burn-Up - (All 1966/67 Units Equipped with C-6 Automatic Transmissions)
  • Article 1306 - Stereo Tape Player Problem Diagnosis - Crosstalk or Slow Tape Speed - (All Vehicles Equipped with the Optional Stereo Tape Player)
  • Article 1307 - Hard Operating Door Windows - (1968 Mustang)
  • Article 1308 - Accessory Relay Terminal Reinforcement - Service Part Number C7TZ-13A435-B - ("W" Series)
  • Article 1309 - Increased Brake Pedal Effort on Units with Power Brake - (All with 6 Cylinder Engines and Power Brake)
  • Article 1310 - Pressure Sensitive Wood Grain Vinyl Transfer Films - Repair Procedure - (1968 Ford, Fairlane Squire Models)
  • Article 1311 - Power Brake Booster Push Rod Adjustments - (1968 Passenger Cars - All Car Lines)
  • Article 1312 - Folding Rear Seat Back Rattles - (1967 Mustang, Model 63)
  • Article 1313 - Improper Diagnosis and Unnecessary Replacement of Warranty Parts
  • Article 1314 - Ignition Point Dwell Angle Variation - (All Current and Past Model Units with Single or Dual Diaphragm Distributors)
  • Article 1315 - Improved "Deep-Cam" Starter Drive Design - (All 1965-1968 Passenger Units)
  • Article 1316 - Rear Axle Noise Complaints - (1967/68 Fords Equipped with Light Duty Axle 8½" 2.80:1 Ratio - Applications Ford 240-1V, 289-2V, 302-2V with C-4 Automatic Transmissions)
  • Article 1317 - Potential Radiator Damage - (1968 Ford and Thunderbird Car Lines)
  • Article 1318 - Starter System Problem Diagnosis - (All 1965-1968 Units with the Autolite Positive Engagement Starter)
  • Article 1319 - Potential Damage to Radiator Upper Tank - (1968 Mustang Equipped with 390 CID Engines and 289/302 CID Engines with A/C or with Extra Cooling)
  • Article 1320 - Fuel Leaking from the Fuel Filler Cap Causing Stained Paint and Loss of Fuel - (Model "C" Cortina)
  • Article 1321 - Driver's Seat Tilts Outboard - ("W" Series)
  • Article 1322 - Floor Member Reinforcement at Cab Upper Latch Mounts - ("W" Series - Sleeper Cab Only)
cron
