Cam for a 300 six
Re: Cam for a 300 six
Glad you like it. What about power gains?
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
08 VW R32
- danno
I haven't drove it but for about 30 minutes,I'm having problems with it running hot.Im thinking about taking the eletric fan off and putting the flex fan back on I didn't have anyproblem when I had it on.I also set the timing at 15 degrees I may need to play with that,what did you set your timing at....
65 f-100 4wd short bed 360engine c-6 tranny
Mine's about 19, I think. I can only approximate because I have a later model harmonic balancer that doesnt exactly match up with my old timing pointer. from what I can tell, it starts at 19*, and full advance is roughly 42*. I find that if the timing is too low, the torque just isnt there like it is where I have it now. I've played with timing so many different ways, I cant even tell you how many times I've opened up the dizzy.
08 VW R32
08 VW R32
