'70 Sport Custom Rebuild- She's been adopted!
- sargentrs
Re: '70 Sport Custom Rebuild - working on doors
I used some sheet metal shears and my cut off tool to cut the piece out.
Now to form the v-break in it. Since I don't have a bench vise, I had to improvise with boards, pipe clamps, hammer and pliers. I clamped the piece between my bench and a board and tapped it down about 45*. Then flipped it over on the other bend line and tapped the other way down about 45%, spun around and repeated on the other bend line.You do not have the required permissions to view the files attached to this post.
- sargentrs
When I was done, I had a halfway decent v-break in my oversized patch piece.
About 45 minutes with my pliers, snips and the bench grinder and I think I've got something that'll work. Had a few more minutes so I started on the outer patches. I had cut a piece of outer door skin from my parts truck before I scrapped it so I used it to mark out my outer patch pieces so I'd match the curve of the door panel.You do not have the required permissions to view the files attached to this post.
- sargentrs
Cut 'em out with my snips
and spent another 20 minutes on the bench grinder and had the front patch ready. That's all the time I had today 'cause I gotta go pay my "honey dues".
- F100builder
Re: '70 Sport Custom Rebuild - patches in progress
It's great to see some great work being done to these old, deserving Ford trucks and keep them on the road! Keep it up!
You're firing up my motivation even more!
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
- Heirloom
Ditto....F100builder wrote:It's great to see some great work being done to these old, deserving Ford trucks and keep them on the road! Keep it up!You're firing up my motivation even more!
~Heirloom
~ Thomas Jefferson
~ Abraham Lincoln
~ Thomas Jefferson
~ Abraham Lincoln
- stephen44
doing good !
thanks
Stephen
Stephen
- tylerb43
Looks good, Randy! Keep it up bud
- sargentrs
Thanks guys!
- mcheath
Wow, you are doing some fancy work. Impressive.
- sargentrs
Re: '70 Sport Custom Rebuild - ready to weld
Second verse, same as the first, could be better but...........
- sargentrs
And the Ford patented corner rot....
I had been dreading this part all along but, all in all, it wasn't too bad. Now to weld 'em in and pretty 'em up.You do not have the required permissions to view the files attached to this post.
- sargentrs
Btw, thanks mcheath!mcheath wrote:Wow, you are doing some fancy work. Impressive.
- sargentrs
Re: '70 Sport Custom Rebuild - bump therapy
So I've been kinda down about not making any progress on my truck. Haven't had a day off work since New Year's and weekends are filled with visiting grandkids, grocery shopping and honey do's. I've been about to blow up! So I took today and Monday off work to spend some quality time in the man cave and do SOMETHING for the truck, anything! Crawled off into the blast/paint booth, dropped the door down and fired up the blaster. Hot, nasty, smelly....just what I needed. After a quality 5 hours of "man time", I had a few parts ready to paint. I feel much better now. Monday, we paint.
- Heirloom
I'm with you on the therapy! Just leave me, my chemicals and tools alone and I'll return a happy man.
Good work! You're making me want to go do more body work!
~Heirloom
~ Thomas Jefferson
~ Abraham Lincoln
~ Thomas Jefferson
~ Abraham Lincoln
- jimmy828
Looks like a lot as been accomplished with the little time that you had
. That sand blasting sure beats the crap out of grinding and sanding no matter what size of blaster is provided.
