Hood Latch Solution
- TexasTruck72
Hood Latch Solution
Hood latch injuries are one the biggest occurances when working on a bumpside, so I came up with a way to protect against it.
The past year I've been using a cut section of a foam swimming pool "noodle" to cover the latch. I simply cut 8"-12" off the end of a pool noodle and cut a slot down one side to the hollow core. It works best if you use one of the hollow, thick, and big noodles(see pictures). When I'm under the hood, I always make sure I have the foam noodle on the latch cause I'm over 6' tall and have had too many collisions with the latch mechanism. I keep it in my truck's toolbox or behind the seat when not in use. Just thought I'd share this solution to hood latch problems. Someone else may have already shared this solution, but I've haven't seen it on fordification yet.
Jack
1943 Ford GPW Jeep(sold)
1972 F-100 Custom
1976 F-150 Explorer
1996 F-150 Eddie Bauer ed.
1972 F-100 Custom
1976 F-150 Explorer
- FormerMarine1981
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Re: Hood Latch Solution
Now if my wife will let me cut the end off one of her pool noodles.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- wildcard
That's the exact same idea I had yesterday. I have a piece like that on my trolling motor blade to keep from tearing the tarp. I was looking at it and decided it would work on my hood latch too.
I guess it's like they say, Great minds think alike.
that almost loooks like my front yard and house across the street too.
Another solution is to put a slice in a tennis ball and then slide it up on the latch.
- TexasTruck72
Not a bad idea, but does the tennis ball absorb/soften the impact of your head? I know the foam noodle does and it makes it just about impossible to get a bruise no matter how hard you hit it.FORDification wrote:Another solution is to put a slice in a tennis ball and then slide it up on the latch.
Jack
1972 F-100 Custom
1976 F-150 Explorer
1972 F-100 Custom
1976 F-150 Explorer
- FormerMarine1981
Even AFTER reading this thread this morning I caught my hood latch .
What we do in Life, Echoes in Eternity
Nice!
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
- forrestbump
Great Idea! I was just getting used to the Bumps and Bruises on my head when YOU come along and change everything!
1970, 2WD, F-250, C/S, Dual Tanks, 390 FE (of course), C6, Power Steering, Power Disc Brakes, Dana 60 3.73, Sky View Blue, Ranger XLT
1970, 2WD, F-250, C/S, A/C, Dual Tanks, 390 FE (again, of course), C6, Power Steering, Power Disc Brakes, Dana 60 3.73, Wimbledon White & Sky View Blue, Ranger (almost twin brothers!)
"One of the greatest discoveries a man makes, one of his great surprises, is to find he can do what he was afraid he couldn't do" - Henry Ford
Larry
Larry
- 390Nut
you would think, that after three or four times of hitting the hood latch, you would learn your lesson. (I still haven't after 30+ years )
Not a bad idea.
Not a bad idea.
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
- Mancar1
It should be called Head Latch, cause it keeps trying to latch ones head to the hood.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- Bumpside Collector
Cool idea! Thanks for sharing it.
CHEESE?!?
Running:
2012 Ford Focus SE hatchback
2007 F-150 XLT Supercrew 4.6 Auto
1972 F-350 Flatbed 360 2V 4 speed
Not Running:
1967 F-100 Ranger Short Bed
1970 F-100 Ranger Long Bed
1972 F-100 Ranger XLT long Bed
1972 F-350 Really long dump flatbed parts truck
1981 F-250 Custom Long Bed (Parting out now)
- Hemmi06
I like it, just got rid of last scab on head from an encounter...
1971 F250 Camper Special
360cu with RV cam and 4v Carb
