swapping a c6 into a 1971 highboy
i have a donor 360 and a c6 that i wish to swap into my highboy project that currently has no transmission. i am wondering if the c6 is too long to use; not sure if a shorter tail shaft is needed or if i can just get a shorter driveshaft to go between the trans and the divorced transfer case.
- basketcase0302
Re: swapping a c6 into a 1971 highboy
Is the original tranny still bolted up? If so, easy to measure from the back of the FE to the back of the OEM tranny.jpiercef
i have a donor 360 and a c6 that i wish to swap into my highboy project that currently has no engine or trans. i am wondering if the c6 is too long to use; not sure if a shorter tail shaft is needed or if i can just get a shorter driveshaft to go between the trans and the divorced transfer case.
Regardless...it's a given it won't be exactly the same, (it will be longer) and you'll have to shorten the driveshaft between the tranny and divorced transfer case. I'd start sourcing your options locally on driveshaft shops, (which there are fewer and fewer these days).
And for the record, my C-6/302 I dropped into BC#16 was tight at the back of the "bell" to firewall clearance wise.
Hopefully someone else can chime in here that has the FE/C-6 combo.
You could switch to a married transfer case on your c6
1972 f250 4x4 390 4speed
- basketcase0302
Def if it were mine! But the NP 205 "married" is the desired TC and getting harder to find.=Jsimon
Currently looking at doing the exact same thing. Thinking it would be as simple as putting a really short drive shaft between the transmission and TC. Also, kind of off topic, but it looks like we will both be looking for an angled oil filter adapter as well as a oil pan thats specific to the 4x4 FEs.
aka englertstephen
depending on how much lift you have , you might get away with a front sump pan.
I hope so. That would make thinks much easier.
aka englertstephen
wait, what? this is new information to me. the 4x4 chassis i bought has the original engine with it. I'll just be able to use the oil pan and the filter off of that, right? i had no idea those two things would even be an issue to begin with.englertsteve wrote: ↑Mon Apr 11, 2022 8:02 pm Currently looking at doing the exact same thing. Thinking it would be as simple as putting a really short drive shaft between the transmission and TC. Also, kind of off topic, but it looks like we will both be looking for an angled oil filter adapter as well as a oil pan thats specific to the 4x4 FEs.
