#11 - Mar. 17, 2007
#11 - Mar. 17, 2007
This one might stump a bunch of you, depending on how far down you've dismantled your trucks:
[img]http://www.fordification.com/board/triv ... -07[2].jpg[/img]
I'd estimate that 90% (or more) of all '67-'72 trucks have two of these. This oval-shaped object is about an inch wide, maybe a tiny bit more. What is it?
re: #11 - Mar. 17, 2007
Looks like a camber washer, What years and models I would not be able to answer if I was correct.
- averagef250
- ezernut9mm
some kind of body shim???
- rjewkes
Is it for the bumper up front to shim it if the frame is bent?
fuelly.com
fuelly.com
- AustinTom
Nobody's even close yet. OK, I'll give you a little hint. The above-pictured item isn't a shim, it's a specialty washer...and there's one on each side of the truck.
...and if you were to slice your truck in half top-to-bottom, these will be located in the top half.
- rjewkes
ahhhhhhhhhhhhhhh! Bach! The washeer behind the striker for the door latches.
fuelly.com
fuelly.com
- averagef250
On bumpside wing windows there's a threaded stud that sticks out the bottom. It has a nut, spring and several metal and plastic washers on it. The specialized washer in the picture looks like the uppermost washer on that lower wing window stud.
- ToughOldFord
Part of the seat belt mount?
...and Dustin got it!! Yep, that's the upper washer for the lower vent window assembly mount. The lower washer is round, the upper washer (yellow arrow) is oval-shaped and is what is featured in this Truck Trivia segment.averagef250 wrote:On bumpside wing windows there's a threaded stud that sticks out the bottom. It has a nut, spring and several metal and plastic washers on it. The specialized washer in the picture looks like the uppermost washer on that lower wing window stud.
- 68F250
Ah-ha! The washer looks a lot bigger in the pic, could you put a pencil or coin by it next time?
Barry
Very good. At least I was the first guess LOL. Nope I was second oh well.
