67 f-100
peanutman
67 f-100
Post by peanutman »
I'm looking at a 67 bump according to the vin it has a 352 engine. Don't know if it is orig engine. How can i look at engine and tell. Dip stick is on drivers side coming out block above pan. Water pump bottom hose is on same side.
It has a four speed, reverse is up and to the right. Knowing this much will the tranny bolt to my 302. If it is a 352 what other parts can i use :? It did not have a 4 speed orig. Hole was cut in floor to add. At on time it had a hurst type shifter probably had a 3 speed at one time.
This truck does have some good usable parts though- chrome grill, chrome front bumper, complete drive line,int parts and it's free i just have to go get it out of a vine thicket,. Need advise.
F10YRB12118
re: 67 f-100
Post by F10YRB12118 »
Dear peanutman,
I have a 67 F100 2WD LB w/ a 352.
I'm new and learning about Ford Bumpsides, I'm no expert, but it could be teh original engine.
The 352 that you describe is exactly like mine. From all info I have on my truck, it's 352 is original.
Here is a pic of my 352.
Sean
1942 Chevy Truck, 1.5 Ton, G503
1967 F100 352 LWB Custom Cab
1969 Bronco Wagon 302
1972 F100 360 SWB 4x4 XLT
1972 F250 360 LWB Parts Donor
1973 F250 360 LWB 4x4 Donor?
1979 F250 460 Parts Donor
F10YRB12118
re: 67 f-100
Pic of my 352, I hope?!
Sean
SteveC
re: 67 f-100
Post by SteveC »
dont forget that the 352 360 and 390 all look the same on the outside
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
flatblack
re: 67 f-100
Post by flatblack »
yes in order to find out you have to measure the stroke, i dont remember the measurements of each engine but im sure someone on here can help you out.
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
re: 67 f-100
Peanutman,
Keith's done all the work for us on ID'ing blocks in this tutorial:
http://www.fordification.com/engineID.htm
And here's your stroke measurements:
http://www.fordification.com/forum/view ... ure+stroke
Basketcase
ford4x4fun
Post by ford4x4fun »
If you do get it and decide to part it out, I have a couple things I would want off of it :thup: Basketcase gave the best advice thus far :thup:
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
truckguy
re: 67 f-100
Post by truckguy »
It has a T-18 in it.
Kyle
Image ImageImage
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1969 f-250 390 CS,ranger, PS,PDB,AC
1968 F-350 360 PB
1968 f-250 360 PB
http://s222.photobucket.com/albums/dd207/truckguy_02/
peanutman
Post by peanutman »
Thanks for all the reply's. Will that tranny bolt up to my 302 bell housing. :? Thanks basket case for the link. Lools like i will have lots of parts available. But i need to know if i can make this tranny work on my 302. :?
