'70 Sport Custom Rebuild- She's been adopted!
Re: '70 Sport Custom Rebuild - Test fitting the seats
Thanks Dan! If anybody wants a drawing, I can provide it
- dantheman71
sargentrs wrote:Thanks Dan! If anybody wants a drawing, I can provide it
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
2002 Ford F-150
No problem. Got 'em ready to send right now. PM me your email address and I'll get 'em to you. Seems I can't figure out how to attach files to PM's or email through the site.
Anybody else out there want them, just PM me your email addy.
I'm debating on whether to just put a center console in or make one that goes from between the seats, all the way up under the dash. Kinda hinges what I do about A/C. I'm still planning that phase out.
- pincheweddo
Re: '70 Sport Custom Rebuild - EZ Cool insulation
Sarge! Looking freakin' awesome dude! Also looking familiarsargentrs wrote:Yeah, don't it? Once I get it put on the roof, I won't have to worry about the aliens reading and controlling my mind anymore
http://www.fordification.com/forum/view ... =6&t=71621
Just returning the
Thanks for the tip, Pinch! I may avoid it on the roof then. I may use your idea on the roof, as a base, but I'd like to put that EZ Cool up there too. That stuff is awesome.
- pincheweddo
sargentrs wrote:Thanks for the tip, Pinch! I may avoid it on the roof then. I may use your idea on the roof, as a base, but I'd like to put that EZ Cool up there too. That stuff is awesome.
Great idea, Pinch!
- dantheman71
sargentrs wrote:No problem. Got 'em ready to send right now. PM me your email address and I'll get 'em to you. Seems I can't figure out how to attach files to PM's or email through the site.Anybody else out there want them, just PM me your email addy.
Sorry for the delay, been a bit busy and haven't been lurking on here much, but THANK YOU for the drawings. Very well done!
1972 Ford F-100
2002 Ford F-150
2002 Ford F-150
My pleasure Dan! Your truck's looking great!
Re: '70 Sport Custom Rebuild - Learning to paint
So a couple of pages back I posted pics of where I painted my cab, doors and such. Wellll....pictures can be deceiving. That day, while wet, everything looked great. It was only after it dried that the ugly showed up. I sanded with 600g, followed by 1500g and proceeded to buff and polish for the final glossy shine. The failure of such is detailed in this other post http://www.fordification.com/forum/view ... =7&t=73463 I won't bore ya'll with repeating it here. To continue, at one point I had sanded through my paint and exposed a little white streak of primer. So a couple of weeks ago, I sprayed my door jambs and repainted that part of my dash. Here's the ugly I mentioned Note the massive orange peel. So after it cured I started sanding again and the OP came out remarkably easy. A little more and that'll be ready to polish. I've been doing a lot of research and realized how little I knew about the whole process so now, armed with my Lake Country wool pad http://www.autogeek.net/foamed-wool-7-5 ... g-pad.html, Eastwood foam 3 pad set with cushioned backing plate http://www.eastwood.com/convex-variable ... -2-in.html, new polish on it's way http://autobodystore.net/Merchant2/merc ... ry_Code=M3 and my just delivered Dura Block set I'm ready to get after it again. Unfortunately, it's too darn cold!
- F100builder
I've got the same Durablock set.
Are you using reducer? What temperature? How far are you from your surface? Looks like you may have too much paint coming through the gun but I'm not positive. Maybe try turning the needle in a little.
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
- pincheweddo
I remember those days... Air pressure? feed rate? thickness? distance? Thats why I like my new little friend, the common paint roller.F100builder wrote:I've got the same Durablock set.
After spending the last month in studying and research, I now know the errors I made the first time around. Should have done that research up front. I've narrowed it down to my gun set up and my spray technique. My air pressure was too low, my air/material mix was too rich and my mix was too thick. I layed down too much, too fast. After spending the last 2 years doing a half a$$ decent job of laying down gallons of POR-15, chassis black and 2K primer I felt like I had a good handle on the painting thing. Well, top coat is a whole nuther beast, ain't it? Guess I got a little cocky and it brought me down to size real quick. I don't think I did any irreparable damage but I made a lot more work for myself than need be. Live and learn. Thanks for the comments and I'd like to hear ya'lls little tips and tricks you've learned the hard way.
- pincheweddo
Air pressure is the biggest issue that I seen folks have. Worse than that is trying a gun you have never used before and trying it out on something important. Had a friend of mine who was on his fourth try of a finish on a motorcycle and his gun sounded like a power washer. Too much pressure.sargentrs wrote:After spending the last month in studying and research, I now know the errors I made the first time around. Should have done that research up front. I've narrowed it down to my gun set up and my spray technique. My air pressure was too low, my air/material mix was too rich and my mix was too thick. I layed down too much, too fast. After spending the last 2 years doing a half a$$ decent job of laying down gallons of POR-15, chassis black and 2K primer I felt like I had a good handle on the painting thing. Well, top coat is a whole nuther beast, ain't it? Guess I got a little cocky and it brought me down to size real quick. I don't think I did any irreparable damage but I made a lot more work for myself than need be. Live and learn. Thanks for the comments and I'd like to hear ya'lls little tips and tricks you've learned the hard way.
I think my problem was more not enough air. I'm using an HVLP gun and I was using my small HF compressor instead of my large compressor because the big one's regulator is broken. The gun is recommended 20-30 psi max. I didn't know how far over that I could go. The spray felt a little weak but I backed off on my material flow to compensate. Also the paint supplier recommended a 1.4mm tip and the closest I had was a 1.3. The combination of these resulting in a weakly spitting spray which gave me massive OP. In the future I'll use the larger compressor for more volume, push the pressure up just a tad, use a larger orifice, add a little more reducer, thin the spray out and apply more, lighter coats, and flashing a little more in between coats.
