BED SIDE PICS
DIXONBOY
BED SIDE PICS
Post by DIXONBOY »
Does anybody have a pic. of a bed side with the upper panel removed. I wa just wondering what it would look like. My is rusted like alot of yours are and I was thinking of tearing it down to fix it but did not know what I am up aganist. I know this has been talked about but I could not find any pics. Thanks.
P.S. Its a wide bed.
Re: BED SIDE PICS
the top part of the bed? the top part of the bed extends down to the floor onn both the styleside and flareside beds on the inside.
DIXONBOY
Re: BED SIDE PICS
Post by DIXONBOY »
I thought the bed was two pieces. My rust is on the outside in the seam. I have seen a thread were they talked about it. I thought the seam was were the two parts split?
FORDification
Site & Forum Admin
Site & Forum Admin
Re: BED SIDE PICS
Post by FORDification »
Yes, the bed sides are in two pieces. Here's a shot I took from the rear of a bed after removing the end cap.
The green arrow points to where the two panels are spot-welded together. The orange arrow points to the backside of the seam, where road debris, salt, dirt, etc. enter between the spot welds and rust this seam out. By the time it gets to the outside where you can see it (yellow arrow), it's usually pretty bad. Just filling the seam on the outside really doesn't do anything except hide the problem for a while...you totally seal it up you also need to seal the backside.
DIXONBOY
Re: BED SIDE PICS
Post by DIXONBOY »
Thank you. Thats just what i was looking for!!
DIXONBOY
Re: BED SIDE PICS
Post by DIXONBOY »
Thanks for going through the trouble of getting that pic. Sorry about that. I just ran across the other thread you posted it in. I noticed there are alot of repeat questions on here.
red403
Re: BED SIDE PICS
Post by red403 »
What is the best way to remove the end cap on the box. I want the 67 caps but the box I am likely going to use is a 70 box. I don't want the light at the back. Just looking for the best way.
FORDification
Site & Forum Admin
Site & Forum Admin
Re: BED SIDE PICS
You can't remove one intact. It's spotwelded in about a hundred places which are impossible to get to to drill out...or weld back in, for that matter. It would be easier by far to just cover the hole for the marker light with a patch panel.
When the '70 model trucks came along with the rear-mounted bed lights, Ford ceased maintaining an inventory of the quarterpanel extensions for the '67-'69 trucks. Instead, they simply kept the '70-'72 extension in stock, as well as this patch, which would've been used to cover the marker light hole and convert the '70-'72 quarterpanel extension to the '67-'69 style. You could whip something up like this from a junkyard truck.
red403
Re: BED SIDE PICS
Post by red403 »
Thanks, I was thinking that cutting the panel out of the cap in my 67 would be the best way to go, then weld it into the newer box.
Re: BED SIDE PICS
i ddi this once. i used a sawzall to cut the end cap off of a bed. i was going to scrap. i just followed down the bed seam line. it was kind of tough to keep a straight line. i did end up cutting into the be side itself before i got down to the bottom. i wish now that i wouldnt have done that to that bed. but its too late.
